Throwing a Code!!
Old Mar 8, 2005 | 07:43 PM
67chevelle's Avatar
Angry Throwing a Code!!
Ok guys, my car is throwing a P0507 code which is the IAC....High idle air control. Anyone know what this is and how i can fix it! any tips would be appriciated. Thanks again
Old Mar 8, 2005 | 08:06 PM
Kataklysm's Avatar
Re: Throwing a Code!!
Well if you got money to throw around just put a new IAC valve in. If not then you'll need to start testing power and ground to the connector. a DMM (digital multimeter) is the best so you can see what the voltage drop is.
Old Mar 8, 2005 | 10:20 PM
There are two things that can set this code.... 1) actual idle speed 100rpm above programmed idle speed, or 2) an "intrusive" test where the PCM opens up the IAC motor by an additional 45 steps, and looks for a specific increase in MAF grams/second flow. Could be a faulty IAC motor (Shoebox has the "checks" on his website), or plugged IAC passages.
http://shbox.com/1/4th_gen_tech1.html
Old Mar 9, 2005 | 12:21 PM
67chevelle's Avatar
Ok thanks for the help guys! Another question?? is it possible this code is beeing thrown because of my supercharger??
Old Mar 9, 2005 | 12:29 PM
Helpful hint.....
When you post a tech question, post all the relavant information. With no info provided in your original post, I assumed you were working with a relatively stock setup. Add a "signature" with year of car, trans type and any majot mods. It will increase your probability of getting the correct answer.
Old Mar 9, 2005 | 07:27 PM
67chevelle's Avatar
Originally Posted by Injuneer
Helpful hint.....
Sry man..I normally post on ls2, ls1,ls1tech! Just became a member of this forum that night and didnt have time to set everything up. Buddy of mine led me to this forum so I wanted to see what yalls opinion was.
lildemars09
May 28, 2015 07:54 PM
beltrunner
May 17, 2015 10:18 PM
Gtpguy
Jan 26, 2015 04:50 PM
BLU98Z28
Jun 20, 2002 08:30 AM
