Best NGK for my 95?
Old Mar 8, 2005 | 07:00 PM
DiabloGT's Avatar
Best NGK for my 95?
which of these NGK spark plugs would u guys think is the best?
-NGK TR55 Spark Plugs Each
stock heat range gapped at .050"
-NGK TR5 Spark Plugs Each
stock heat range gapped at .035"
-NGK TR6 Spark Plugs Each
one heat range colder than stock gapped at .035"
-NGK R5724-8 Spark Plugs Each
three heat ranges colder than stock gapped at .032"
-NGK R5724-9 Spark Plugs Each
four heat ranges colder than stock gapped at .036"
thanks if you can help!
Old Mar 8, 2005 | 07:14 PM
fesgali's Avatar
Re: Best NGK for my 95?
If it's stock either go with some stock ones or the TR55. Others are good also but for more modified cars/engines.
Old Mar 8, 2005 | 07:29 PM
Birdman7389's Avatar
I run TR55's gapped at .050 on my mild bolt on car......
Old Mar 9, 2005 | 04:08 PM
DiabloGT's Avatar
im gonna highly mod my camaro, and heads/cam , lt , 3500 stall, and all those, what should i pick ,and around next year maybe 396 and twin turbo? which would u reccomend?
Old Mar 9, 2005 | 06:07 PM
trans9_5am's Avatar
I would get the TR55's and gap them to .035 or .040
Brandon
Old Mar 9, 2005 | 07:33 PM
crazy_jackalope's Avatar
Why not just use stock plugs with stock gap?
HarleyZ28
Oct 5, 2015 06:23 AM
Slayer
Aug 17, 2015 03:55 PM
BMX Dad
Aug 15, 2015 01:15 PM
BLK1997Z28
May 7, 2015 03:01 PM
