Throw away compressor?
Old Mar 20, 2011 | 08:47 AM
trikergirl's Avatar
Smile Throw away compressor?
I have a z28 V6 1996 which the ac does not work but not a problem here in the UK, I would rather open the windows!.The noise has been getting steadily worse from the compressor and could possibly be a bearing(have changed the idler pulley) Can you remove the compressor and get a smaller belt.If so doea anyone know which size and any tips on how to rework.Thanks
Old Mar 20, 2011 | 09:02 AM
Re: Throw away compressor?
Welcome to CamaroZ28.com !!
Your post is a bit confusing. You indicate you have a Z28 V6. All Z28 models 93-97 have the LT1 V8. Only the base model Camaro had the 3.8L V6 in 1996.
If its actually an LT1 V8, there is an "A/C delete" pulley that allows you to eliminate the A/C compressor, while maintaining the stock serpentine belt routing, and (in most cases) the stock belt length. Not sure if there is something similar for the V6.
Old Mar 20, 2011 | 09:03 AM
Kevin Blown 95 TA's Avatar
For V-8...Yes, you can get an AC delete pulley to replace the AC compressor and use the same belt. They used to cost about $26 at the dealer here but I have seen them for more around $40+ on EBAY usually, however every once in a while someone is selling one in the parts section. If you do a search, I'm sure more information will pop up.
Old Mar 20, 2011 | 12:02 PM
trikergirl's Avatar
Thanks now confused. The car was originally imported from Japan and has Z28 on the front wing, maybe someone added that? Husband says it is a straight 6 not V6, does that make a difference?
Old Mar 20, 2011 | 12:15 PM
19z28camaro02's Avatar
Taking a picture of the engine and posting it is pretty much going to be your only option for identifying it.
Old Mar 20, 2011 | 12:19 PM
OBE1 95Z28's Avatar
1996 Camaros were never produced with straight 6's; it's either a V6 or a V8 if the car is stock.
Old Mar 20, 2011 | 06:22 PM
mike2's Avatar
Send pics.
Ericksd
Jan 20, 2016 06:07 PM
PopoFormula
Oct 12, 2015 04:19 PM
War Engine
Sep 18, 2015 07:28 PM
WPHIG2
Aug 27, 2015 06:37 AM
AtlasXVIII
Aug 24, 2015 11:41 PM
