Throttle response any ideas?
Old Mar 23, 2007 | 01:36 PM
NTRBTR97Z's Avatar
I have a 97z28 M6, when I open it up shifting seems to kill me. The car gets up to the redline I shift and the rpms drop and have to catch back up? Does this have anything to do with the traction control system? I obviously dont use it but if it is, is there a way to eliminate it?
Old Mar 23, 2007 | 04:16 PM
BUBBA's Avatar
Traction Control? Didn't know you had it. Anyway, you are probably hitting the rev limiter which is mostl likely set at 5800, therefore when you are rowing though the gears and hit the limiter you are naturally going to loss rpms. Or you are hitting valve float because the stock springs tend to peter out at high rpms.
Get some stronger springs and have your limiter set higher. And...please enlighten me about the Traction Control on an M6---I have an SS, so perhaps mine didn't come with the Control.
Thx.
DirtyDaveW
Dec 1, 2016 05:37 PM
Cam's maro
Mar 24, 2015 08:09 PM
armedtrigger
Feb 24, 2015 08:30 PM
94Form
Feb 10, 2015 11:23 PM
Ricardo
Nov 29, 2014 10:58 AM
