94 z-28 skipping can't pull codes
Old Mar 22, 2007 | 06:41 PM
opusman's Avatar
Question 94 z-28 skipping can't pull codes
94 z-28 idles rough when you try to accelerate while driving it has no power and valves rattle / spark knock. I tried to pull the codes OBD 1 the cooloing fans come on but the light does not flash at all not even the 12 check code. Anyone have any ideas ??????????
thanks
Old Mar 22, 2007 | 08:23 PM
z28-06's Avatar
umm check the cat. It may be clogged
Old Mar 23, 2007 | 05:10 PM
You can NOT flash the codes on the SES light on an LT1 newer than 1993. You need a "real" scanner, or scan software to pull the codes.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
RUENUF
Mar 13, 2016 03:39 PM
Gtpguy
Jan 26, 2015 04:50 PM
Darth Xed
13
Jul 22, 2002 12:45 PM
