throttle response
Old Nov 26, 2003 | 04:12 PM
Marcus34's Avatar
throttle response
my car idles at 400 rpm's, but when we push on the accelerator we get no response, acceleration
Old Nov 26, 2003 | 09:30 PM
What car, what engine, what year, what mods?
Old Nov 26, 2003 | 11:02 PM
96z's Avatar
96z
Injuneer may already know this but this maybe needed to be moved to LT1 tech.
Old Nov 27, 2003 | 10:34 AM
Marcus34's Avatar
1994 trans am lt1, flowmaster cat back, cc306, bored over a little and cai. i think thats it.
Old Nov 27, 2003 | 11:38 AM
LT1 questions should be posted in the LT1 Tech forum. Moving it there......
Old Nov 27, 2003 | 12:18 PM
tryintogofast's Avatar
Is the throttle cable connected properly to the throttle body? If anything it should die if you expose it to more fuel. That it might also be a bad fuel pressure regulator whats the psi?
Old Nov 27, 2003 | 02:40 PM
b-stevens's Avatar
Your idling at 400 rpm with the cc306? daaaaaamn...
Old Nov 27, 2003 | 06:35 PM
Antz97ZNJ's Avatar
check the throttle cable connection, tighten it up
Old Nov 27, 2003 | 06:52 PM
Seal's Avatar
if nothing happens, then ur throttle cable isnt hooked up, cuz ur butterflies wont open (the cable opens it)
even if there were other probs (like fuel) when the butterflies open up, the RPMs will jer around cuz more air will come in....
if nothign happens, than its ur cable
Old Nov 27, 2003 | 09:49 PM
AutoRoc's Avatar
400RPM? GEt it to idle around 750-800 at least I'm guessing. Then it won't try to kill itself when the throttle is touched.
93 RedBird
Nov 15, 2015 08:24 AM
PopoFormula
Oct 12, 2015 04:19 PM
Tarizza
3rd Gen / L98 Engine Tech
Sep 20, 2015 03:26 PM
tommalcolm
Sep 11, 2015 03:39 PM
RX Speed Works
Sep 11, 2015 03:31 PM
