Throttle Position Voltage Question
Here is my data:
Idle: 0.39 volts
WOT: 3.92 volts
I need a new throttle position sensor correct?
There should be a 4.0 volt difference no?
Idle: 0.39 volts
WOT: 3.92 volts
96Z:
Car doesn't kick down to first gear from a 25mph roll when I go WOT. Only kicks down to 2nd.
Car shifts in every gear at 5000rpm instead of 5700 when you don't manually shift it.
Car seems a bit sluggish.
You are kind of on the low side of the scale at both ends, but have you a way to look at it with a scanner to see what % throttle the pcm is calculating from those voltages? If it is calculating 0%-100%, then it should work ok. Having said that, some people have reported better response when the low setting is ~.6v or so.
You could try slotting the mounting holes in the TPS to try to raise the initial voltage and thereby hopefully increasing the WOT voltage, too. Just a thought, before you lay out cash for a new TPS. I know you have other things to spend your money on.
Originally posted by Hybrid_LT1
Isn't it supposed to be over 4.5 volts?
FYI, a reading of 4.8v or higher for 1 second will throw an SES light so just under that would be the high end of the band.
Originally posted by Gripenfelter
Thanx guys.
Mr. Shoe: slot the back side of the mounting holes so it sits closer to the TB?
Thanx guys.
Jul 4, 2005 05:00 PM
