throttle NOT retuning ALL the way closed BBK 58?
Old Apr 19, 2006 | 10:15 PM
  #16
94formulabz's Avatar
Re: throttle NOT retuning ALL the way closed BBK 58?
Originally Posted by 30th TA 0219
Sometimes the throttle blade stays open just a little bit, causing a high idle. I can close it the remaing few degrees by hand. What is binding up in it to cause this? It is VERY annoying, and makes it difficult to drive in traffic.
If the TB isn't dirty and its still doing that it may be because you dont' have quite enough slack in the throttle cable. I had this problem on a brand new AS&M 58mm.
Adding an extra spring as someone suggested can work, but can also be tricky for find the right one at the right length.
My suggestion would be to take an adjustable wrench and with the throttle cable removed rework the black stamped steel bracket where the cable housing stops. Clamp the adjustable on tight and then torque on the bracket in different spots to move it a couple millimeters forward closer to the TB. It won't take much bending to get it right, plus you won't have a big ugly spring hanging off of there forever.
Good luck,
Brent
Old Apr 20, 2006 | 02:09 AM
  #17
LUCIFER2's Avatar
had a similar problem with my 58 mm throttle body but it was very sensitive when i gave it gas so my mechanic just gave the return spring another turn and tightened it up
Old Apr 20, 2006 | 08:49 AM
  #18
EVERESTZ28's Avatar
I had this problem and I soldered it, now always return to the same point.
Old Apr 20, 2006 | 12:50 PM
  #19
30th TA 0219's Avatar
it looks like it was soldered, but broke, maybe I'll put a dab of JB Weld on it! lol
Peytons'z
May 6, 2021 09:25 AM
oldschool
Feb 9, 2016 09:21 PM
alphaauto
Jan 23, 2015 07:42 AM
lt1-xjs
Jan 17, 2015 07:52 PM
Mike Meyers
Aug 14, 2002 01:26 PM
