Aftermarket harmonic balancers
Old Apr 20, 2006 | 12:12 PM
96ssblack's Avatar
Question Aftermarket harmonic balancers
Are after market harmonic balancers worth the 300 dollars that you put into them. I know they help with vibrations but what level of horse power makes these things worth while. Thanks for the help
Old Apr 20, 2006 | 12:29 PM
Z28SORR's Avatar
Re: Aftermarket harmonic balancers
Well a lot of people think so. I beleive it's more rpm then hp though. And of course it eliminates the two piece construction of the stock design.
Old Apr 20, 2006 | 01:02 PM
One advantage is in the "SFI" rating..... required by NHRA, etc. for running under 11.00
The use of a crank key is a plus, and for engines spinning over 7,000rpm there is an advantage in reduced torsional vibration.
Keep in mind, its a "damper" not a balancer.
Jeff1904
Jun 5, 2016 05:00 PM
Kinglouui
May 26, 2016 11:05 AM
Bigfatrat
Parts Wanted
Oct 16, 2015 04:48 PM
CARiD
Sep 30, 2015 05:44 AM
Daluchman1974
Sep 11, 2015 06:12 AM
