Throttle Body to valve cover hose, oil getting in TB.. STOP THIS!
Old Feb 18, 2004 | 10:22 PM
  #16
CoUnTryMuZiCZ28's Avatar
But there is alot of smoke coming out of my neck.. its not suppose to! Both necks.... mine and the cars! ... The smoke out of the exhaust looks like condensation..
Old Feb 18, 2004 | 10:23 PM
  #17
The pics dont show it. you cant see the smoke or anything.. What rings not sealing? Its a tinny steady stream of smoke.. like a steady line.. but you have to REALLY look to see it...
Old Feb 18, 2004 | 10:26 PM
  #18
Ummm, piston rings.
Old Feb 18, 2004 | 10:27 PM
  #19
Can it possibly be something else? What about because i dont have my car tuned yet? Maybe the valves are staying open longer? or somthing... Could it possibly not be the piston rings?
Old Feb 19, 2004 | 12:53 PM
  #20
bigde4u's Avatar
Not trying to hijack your post here, but do you remove the pcv valve and replace it with the breather filter?
Old Feb 19, 2004 | 03:29 PM
  #21
No.. The breather filter goes on the valve covers... Where the line goes to the TB, on that line but on the valve cover..
Old Feb 19, 2004 | 04:40 PM
  #22
bigde4u's Avatar
Old Aug 2, 2004 | 11:32 PM
  #23
ZPower_123's Avatar
Re: Throttle Body to valve cover hose, oil getting in TB.. STOP THIS!
What is the point of having that valve cover line that goes to the TB?
Old Aug 2, 2004 | 11:39 PM
  #24
It provides metered air to the PCV system. If there is excessive pressure in the crankcase, oil entrained air can also travel in reverse, back toward the throttle body.
Old Aug 2, 2004 | 11:55 PM
  #25
ZPower_123's Avatar
Originally Posted by fulltiltpimp
Yea I blocked off the the pcv to the T-Body and put a K&N valve cover fiter on... But now it huffs like a champ thru the filter under high revs.... is there another way to vent this crap?? Cuz I know if I hook up the pcv then it will get all clogged up again ....
So your saying the k&n valve cover filter is no good ?
Old Aug 3, 2004 | 12:11 AM
  #26
No, he means his rings are. Too much blow-by.
If you want to entertain yourself on the subject of the PCV system, read this http://web.camaross.com/forums/showthread.php?t=164835 .
Old Aug 3, 2004 | 05:17 AM
  #27
slopokrodrigez's Avatar
At this point, country should be doing a couple of things. First a leak down test of the all the cylinders is a must. Then he should put a manometer on the oil dipstick and see what the crank case vacuum level is. I would put money on either a bad PCV system, bad head gasket and last bad cylinder.
To follow up, hey country, did you ever have a bad cylinder in the past where it wasn't firing?
Old Aug 3, 2004 | 05:20 AM
  #28
What? I havent had this problem in ages.. lol.. My motor isnt even in my car.. check sig.. no all my cylinders have always fired, some missfire but still fire..
Old Aug 4, 2004 | 04:22 PM
  #29
RobbyRob's Avatar
Your sig sound like the bionic man. Remember that tv show from the 70's.
Old Aug 4, 2004 | 04:29 PM
  #30
Trmpt63529's Avatar
dude... your getting blow-by.....as in it blows by the rings! leakdown test!!!
HectorM52
Jul 30, 2017 11:46 AM
Jazsun
Dec 29, 2014 12:14 PM
Queens94z28
Dec 20, 2014 09:11 PM
Jul 4, 2005 05:00 PM
