Throttle Body to valve cover hose, oil getting in TB.. STOP THIS!
The pics dont show it. you cant see the smoke or anything.. What rings not sealing? Its a tinny steady stream of smoke.. like a steady line.. but you have to REALLY look to see it...
Re: Throttle Body to valve cover hose, oil getting in TB.. STOP THIS!
Originally Posted by ZPower_123
What is the point of having that valve cover line that goes to the TB?
Originally Posted by fulltiltpimp
Yea I blocked off the the pcv to the T-Body and put a K&N valve cover fiter on... But now it huffs like a champ thru the filter under high revs.... is there another way to vent this crap?? Cuz I know if I hook up the pcv then it will get all clogged up again ....
So your saying the k&n valve cover filter is no good ?
If you want to entertain yourself on the subject of the PCV system, read this http://web.camaross.com/forums/showthread.php?t=164835 .
At this point, country should be doing a couple of things. First a leak down test of the all the cylinders is a must. Then he should put a manometer on the oil dipstick and see what the crank case vacuum level is. I would put money on either a bad PCV system, bad head gasket and last bad cylinder.
To follow up, hey country, did you ever have a bad cylinder in the past where it wasn't firing?
Originally Posted by CoUnTryMuZiCZ28
What? I havent had this problem in ages.. lol.. My motor isnt even in my car.. check sig.. no all my cylinders have always fired, some missfire but still fire..
Jul 4, 2005 05:00 PM
... The smoke out of the exhaust looks like condensation..
