Throttle Body to valve cover hose, oil getting in TB.. STOP THIS!
Old Feb 18, 2004 | 06:20 PM
CoUnTryMuZiCZ28's Avatar
Angry Throttle Body to valve cover hose, oil getting in TB.. STOP THIS!
Ok.. Im getting a HUGE amount of oil in there.. If i pull the tube off it DRIPS out!!! AHH.. OK so yea how do i fix this.. The TB is loaded up with it! Its making me blow blue smoke from my exhaust.. and probably getting on everything else!
Old Feb 18, 2004 | 06:25 PM
DonHood's Avatar
I'm glad someone else brought this up. I remember seeing a thread about it a while back, and there was a filter you could buy from Advance to go in between the valve cover and TB. But I can't for the life of me remember what the part number was. Been trying to search for it for a while.
Old Feb 18, 2004 | 06:26 PM
Yea it goes onto the back of the TB.. I guess i would get that.. But i wanna stop this like NOW.. lol
Old Feb 18, 2004 | 06:36 PM
DonHood's Avatar
Found it.
It's the Deutsch BF412 breather filter.
Old Feb 18, 2004 | 06:38 PM
yea thats it! Where do you get it now? I still wanna fix this first.. then ill put that on as added protection..
Old Feb 18, 2004 | 06:41 PM
http://collop.cz28.com/custom2.html got it!.. DO you yahoo?
Old Feb 18, 2004 | 06:43 PM
DonHood's Avatar
I'm sure Advance or Auto Zone would probably carry it. Also I think it's a fairly common problem with LT1's, so adding the filter should be about all the 'fix' you need. Sounds like yours is particularly bad though if it's causing your exhaust to smoke, mine is just a little residue under the inspection plate.
Old Feb 18, 2004 | 06:54 PM
yea mines horrible
Old Feb 18, 2004 | 08:14 PM
RobbyRob's Avatar
Mine sucks some oil up but not that much.
Old Feb 18, 2004 | 08:18 PM
JasonK94Z's Avatar
Talking
I just ran into this today on the board. Glad you brought it up. I found the following:
Purolator B23165
Deutsch BF412
Fram BA6592
Also check your pcv valve.
Old Feb 18, 2004 | 08:32 PM
If you have that much oil coming through that hose, your PCV system is not working well or you have excessive blow-by from worn rings.
Old Feb 18, 2004 | 08:47 PM
fulltiltpimp's Avatar
Yea I blocked off the the pcv to the T-Body and put a K&N valve cover fiter on... But now it huffs like a champ thru the filter under high revs.... is there another way to vent this crap?? Cuz I know if I hook up the pcv then it will get all clogged up again ....
Old Feb 18, 2004 | 09:06 PM
SHOEBOX!!! HELP!!!! I might have a problem.. The car smokes white ish smoke out of the tail pipes on start up.. When you rev it a little it goes away for a little while.. The oil system also smokes.. When you take the oil cap off and look from the side you can see a tiny tiny bit of smoke coming out of the neck.. The oil color seems fine to me... the coolant color is like water because i havnt changed the coolant yet since the cam install and i put only water to clean it out, it looks kinda cloudy ish.. i have pics.. do you mind if i send them to you?
Old Feb 18, 2004 | 09:27 PM
DonHood's Avatar
You should see what comes out of the valve covers on my Blazer.
Old Feb 18, 2004 | 10:22 PM
Depending on air temp/humidity, every car puts a little vapor out the tail pipes on start up. When warm, if you remove the oil cap and get puffs (I know Injuneer likes to say "huffs" ) of smoke out, it is an indicator of rings not sealing.
You can send pics if you want. I can't guarantee if I can tell anything.
