throttle body problems
Old Feb 13, 2007 | 09:55 PM
slp97camaro's Avatar
hey guys. i have a 52mm BBK throttle body on my camaro, and ever since ive had the car its had a high idle due to something w/ the throttle. Ive taken the tb off and cleaned the bore out completely to see if that would help...but its like when its on the car the blades dont want to close all the way. sometimes it will close all the way...but most of the time if im driving...then just push the clutch in...it sticks around 2300-2500 rpms, then if i hit the throttle really fast it will snap closed the rest of the way. So im guessing it has to do w/ the alignment of the blades? could anyone help me on how to adjust these? it gets pretty annoying after a while
thanks a lot
Old Feb 13, 2007 | 10:00 PM
DelSoto's Avatar
I have seen where guys have to modify the return spring....adding more closing force.
Old Feb 13, 2007 | 10:17 PM
i know exactly what your talking about, but ive already tried putting a heavy duty spring on there, and for some reason it still doesnt want to work.. haha thanks for the response though
Old Feb 13, 2007 | 10:57 PM
2000GTP's Avatar
Is the throttle cable or butterfly valve being caught or kinked on anything to cause the blades to get caught open?
Old Feb 13, 2007 | 11:04 PM
nope, im almost 100% sure that those are alright. throttle cable was fine when i took it off, and i made sure i put it back on right after i cleaned it...and it did the same thing.
Old Feb 14, 2007 | 05:53 PM
ttt anyone??
Old Feb 14, 2007 | 06:54 PM
pvollman's Avatar
You need to make sure that your TPS is adjusted to .5volts I believe. Sounds like the throttle blade isn't shutting all the way. I have had 2 of the 52mm and seriously believe they are not worth the money! You will get a better result from a custom PCM tune. IMO.
Old Feb 14, 2007 | 09:57 PM
yeah, im not very fond of my 52mm right now...it came on the car though so i just left it on...im thinking of just upgrading to a 58mm even though i probably dont need to, but i am getting heads/cam this summer...so idk
Old Mar 5, 2007 | 12:30 PM
TwEaKeDSS's Avatar
thanks a lot
Did you ever fix the problem??? This is EXACTLY what my car is doing after going from a 52mm BBK to the 58mm BBK. For some reason my 52mm never did this. ANy help would be appreciated.
Old Aug 20, 2008 | 06:26 PM
Jditlfm's Avatar
My 58 does this same thing any insite?
HectorM52
Jul 30, 2017 11:46 AM
4586
Parts Wanted
Mar 17, 2015 11:24 PM
lt1-xjs
Jan 17, 2015 07:52 PM
Queens94z28
Dec 20, 2014 09:11 PM
Jul 4, 2005 05:00 PM
