Throttle Body Plate
Old Mar 21, 2005 | 10:53 AM
1-bad-z28's Avatar
Throttle Body Plate
I was wondering if there is anything special on the bottom of the TB plate. I can have one made for free if I can just bolt a flat piece of metal on it. I was looking at the stock one and it looks like it has passages of some sort. Does the custom one need the exact same passages?
Old Mar 21, 2005 | 11:06 AM
CamaroBoy96Z28's Avatar
Re: Throttle Body Plate
No there's nothing special there. Just seal it with the TB gasket.
Old Mar 21, 2005 | 11:08 AM
1-bad-z28's Avatar
What are the passages for?
Old Mar 21, 2005 | 11:24 AM
DavesLT1's Avatar
the bottom plate is for coolant isn't it?
Old Mar 21, 2005 | 11:26 AM
If you mean the plate on the bottom of the TB, you certainly cannot remove it. The IAC is in there.
Old Mar 21, 2005 | 11:35 AM
89305rs's Avatar
i THINK he is talking about the BOTTOM of the top plate?
Old Mar 21, 2005 | 12:41 PM
1-bad-z28's Avatar
Exactly...the bottom of the top plate. I want to make a custom one but not sure why the stock one has grooves in it. Anybody with an aftermarket one should know if theirs is smooth or not.
Old Mar 21, 2005 | 12:47 PM
InGodITrust's Avatar
I have an aftermarket one and it is 100% smooth on the bottom side! Just get a new gasket and you'll be ok!
Old Mar 21, 2005 | 12:51 PM
1-bad-z28's Avatar
cool....thanks. That is all i need to know. Not that it matters anymore, but why is the stock one shaped like it is? Is there a reason behind it or is it like so many other things......"it just is".
HectorM52
Jul 30, 2017 11:46 AM
oldschool
Feb 9, 2016 09:21 PM
DirtyDaveW
Mar 15, 2015 07:01 PM
Queens94z28
Dec 20, 2014 09:11 PM
