How to remove crankshaft sprocket
Old Mar 21, 2005 | 11:23 AM
Propower1124's Avatar
Banned FOR SCAMMING - Nick[William] Dascal - (516) 931-0586
How do i remove the crankshaft sprocket?
And i stripped the threads on the thing that the crankshaft sprocket, is that fixable?
Old Mar 21, 2005 | 11:34 AM
Re: How to remove crankshaft sprocket
The crank sprocket is removable with a two or three jaw puller.
The second sentence I don't understand.
Old Mar 21, 2005 | 11:45 AM
89305rs's Avatar
i think he means the hub bolt hole in the crank
Old Mar 21, 2005 | 11:58 AM
Yes the hub bolt hole, i stripped the beginning of the threads
Does anyone know the tread size for that?
Old Mar 21, 2005 | 12:34 PM
BlkLT1Z28's Avatar
There is a very easy way to remove the crank gear.
1) with a puller
2) with a hammer and a good sized flat head screw driver. Put the screw driver between 2 of the teeth closest to the dowel pin. Give a good wack and the gear will split in half and that is it. Just make sure you wack it and not hit it. I mean dont follow through because you can go through the gear and hit the crank. But you should be fine.
Old Mar 21, 2005 | 01:32 PM
7/16-20
War Engine
Aug 28, 2015 06:04 AM
Slayer
Aug 17, 2015 03:55 PM
4586
Jul 31, 2015 06:03 PM
mrwz28
Jul 8, 2015 09:11 PM
SergheiS
Jul 5, 2015 03:27 AM
