Throttle body mods?
Old Dec 13, 2003 | 09:40 AM
Myxtreme1's Avatar
Throttle body mods?
Okay, besides the bypass and porting it, isn't there some other free mods I can do to the throttle body and surrounding area?
Old Dec 13, 2003 | 09:44 AM
1996 | Z28 SS's Avatar
Um.. only thing I can really think of is a good clean... and I guess an air foil lol
edit: even though air foil isn't free... but I just though of something else that could be... it's not really the TB but it's the intake elbow.. if you haven't already, you can remove that bellow and plug it up to smooth out air flow.
Old Dec 13, 2003 | 09:54 AM
Myxtreme1's Avatar
I took off the bellow (resonator or whatever it is called) when I did the opti . I'm thinking I might go ahead and remove the tb and replace both gaskets and clean it up real good like you said.
Old Dec 13, 2003 | 11:15 AM
ibanez6rg's Avatar
Move the IAT sensor farther away from the TB.
Old Dec 13, 2003 | 11:25 AM
Myxtreme1's Avatar
What will that do?
Old Dec 13, 2003 | 11:44 AM
ibanez6rg's Avatar
Originally posted by Myxtreme1
What will that do?
Give you more accurate temp reading - Stock its not hard for them to get heat soak (during long drives and what not) and can actually cause knock problems. It will oomph up you're timing a bit, also.
Potent77
Mar 16, 2022 12:13 AM
Peytons'z
May 6, 2021 09:25 AM
HectorM52
Jul 30, 2017 11:46 AM
4586
Parts Wanted
Mar 17, 2015 11:24 PM
DirtyDaveW
Mar 15, 2015 07:01 PM
