throttle body issues need help!
Old Jun 23, 2011 | 09:42 PM
mj1993z28's Avatar
I just took off my throttle body and cleaned it... wow 250,000 miles of a throttle body not being cleaned is bad . anyways cleaned it all up and my idle air control valve. I started the car after everything was put back together. ran smooth for 30 sec or so.. then i reved it up and now it idles at 1500 rpm . No matter if i unplug the battery or not.. what did i do wrong ???
Old Jun 23, 2011 | 10:06 PM
BadAssed93Z's Avatar
Re: throttle body issues need help!
nothing, the car has learned to idle with such limited flow because it was dirty, now that its clean there is much more air getting through the iac and around the blades, it will eventually relearn or you can adjust the idle screw.
Old Jun 24, 2011 | 12:54 AM
mrmint69's Avatar
My first thought is it got stuck in the wrong position. They are sensative and you need to be careful.
Old Jun 24, 2011 | 07:31 AM
mj1993z28's Avatar
doh stuck ... i hope not. I dont need to re set the TPS sensor do i ? and i cleaned the air control valve with carb cleaner and i tooth brush ... is that ok way to do it ?
Old Jun 24, 2011 | 08:14 AM
my1994z28's Avatar
As mentioned in the other post you made,to quote Injuneer"you are not suppose to use any solvent on the Iac or you will damage it"...
Old Jun 24, 2011 | 08:33 AM
bw_hunter's Avatar
That's not exactly what he said nor is the above correct. The IAC can be cleaned if care is taken to keep solvent, especially gunk laden solvent, out of the electrical part of the sensor. All you have to do is hold the sensor with the motor up and spray away. The solvent will remove the gunk and drain away from the motor.
When cleaning anything on the throttle body it's best to use a cleaner that states that it is safe for coated blades.....
Old Jun 24, 2011 | 05:04 PM
I love it when people misquote me. It also annoys me when I answer the question in one place, and the OP starts a new thread, and ignores what I posted.
https://www.camaroz28.com/forums/sho...d.php?t=818597
Old Jun 29, 2011 | 08:28 PM
mj1993z28's Avatar
Ok i have a 1993 camaro so is there any torque specs on the iacv ?? considering its all connected already and there is no way to adjust the spring etc.
HectorM52
Jul 30, 2017 11:46 AM
4586
Parts Wanted
Mar 17, 2015 11:24 PM
jackpawt883
Feb 26, 2015 09:04 PM
David Dorris
Jan 17, 2015 08:10 PM
Queens94z28
Dec 20, 2014 09:11 PM
