throttle body bypass question
Old May 12, 2004 | 01:48 PM
johnnyt's Avatar
once you take the hoses off the throttle body do you have to patch the holes up?
doing this now and cant get to the passenger side hole to patch it
thanks john
Old May 12, 2004 | 01:54 PM
dabear95's Avatar
I would recommend it, although thinking about it I can't say it will cause a problem if it is not plugged.
Jason
Old May 12, 2004 | 01:56 PM
Red96Lt1's Avatar
I didn't plug mine back up. If you ever plan on reconnecting the coolent line to the TB, I would recommend plugging the holes. Otherwise, don't worry about it.
Old May 12, 2004 | 02:09 PM
BUBBA's Avatar
Throw a couple of 3/8" vac caps on them. At least you won't be dumping water in there should you hose down your engine.
HectorM52
Jul 30, 2017 11:46 AM
4586
Parts Wanted
Mar 17, 2015 11:24 PM
Queens94z28
Dec 20, 2014 09:11 PM
Jul 4, 2005 05:00 PM
RedLineRev
Jan 23, 2003 03:51 PM
