Throttle Body Bypass Help!!!!! =/
Old Aug 13, 2006 | 02:11 PM
miaminick's Avatar
Hey,
You know that hose thats a pain in the *** to get to when you do this mod? The one under the TPS... I have to cover up the open hole with a vaccum cap right? I can't just leave it uncovered? Just making sure
Old Aug 13, 2006 | 02:16 PM
silentsprintero's Avatar
Re: Throttle Body Bypass Help!!!!! =/
yep just put a cap on it and put something like clear rtv or something around it to make a water-proof, air-tight seal
-Chris
Old Aug 13, 2006 | 02:17 PM
L31stang's Avatar
Mine has been uncoverd since i got the car so I hope its ok
Old Aug 13, 2006 | 03:09 PM
miaminick's Avatar
Cool. Can someone fill me in as to how this increases HP though?
Old Aug 13, 2006 | 03:10 PM
LT1_383's Avatar
It's not vital that it's air tight or covered at all. It dosn't go anywhere.
Old Aug 13, 2006 | 03:28 PM
It takes a little heat out of the incoming air. Cooler, denser air can make more horsepower.
Old Aug 13, 2006 | 05:18 PM
Dyno test, with a few words of explanation:
http://www.ws6.com/mod-8.htm
Old Aug 13, 2006 | 05:22 PM
Z28LT1_Just_Nasty's Avatar
It's not vital that it's covered it just looks nicer.
Old Aug 13, 2006 | 07:22 PM
PredatorZ28's Avatar
i just unhooked the longer hose and hooked it to the metal line and didnt have to connect the two rubber hoses together at all
Old Aug 13, 2006 | 07:31 PM
LT1_383's Avatar
The earlier years had a different setup. I beleive 95+ just had to connect the long hose to the steam pipe.
Old Aug 13, 2006 | 07:49 PM
miaminick's Avatar
Awesome. Done and Done. Pretty simple... punctured a hose while at it but had enough play in the line to cut up to the leak and re-clamp it.
I felt the crispness in throttle right away
Old Aug 13, 2006 | 10:05 PM
That's because you have a 95, and its not the same as a 93/94.
HectorM52
Jul 30, 2017 11:46 AM
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
warmeck
May 1, 2015 11:30 AM
RedLineRev
Jan 23, 2003 03:51 PM
