Throttle Body Bypass on a 94..
Well was going to to the throttle body bypass but can't find any info on what to do if you have the T coming off the bleader pipe I guess. The metal pipe that has the screw in it to bleed out the air.
Right now i have nothing going to the nipple under the throttle body.
Would I have to find a way to replace that entire line or is there another trick to block off that T?
Mike
Mike
