Throttle body bypass on a 94
Old Jul 25, 2003 | 02:24 PM
1994CamaroZ28's Avatar
Can you do it and if so does anyone have a guide or pictures noticed shoebox has one for like 95-97 but not 94 any help will be much appreciated
Old Jul 25, 2003 | 02:37 PM
Take the hoses off the two coolant connections on the bottom of the throttle body, and connect the hoses together using a 3/8" barbed hose connector, and a clamp on each side. Make sure you don't drip any coolant on the Opti, and bleed the air out of the system correctly when you are done.
[EDIT] Added a link
Old Jul 25, 2003 | 05:37 PM
Stormman's Avatar
Originally posted by Injuneer
...and bleed the air out of the system correctly when you are done...
Excuse my ignorance,but how does one go about doing that?
Old Jul 25, 2003 | 06:48 PM
Just got it done now my engines running ruff most of got a bit of water on the opti is only thing i could think of what you think?
Old Jul 25, 2003 | 07:45 PM
CamaroGuy22's Avatar
I am about to do this mod
Old Apr 18, 2004 | 09:27 PM
Black6SpdTA's Avatar
Bringing this thread back from the dead, but how do you do bleed the system?
Old Apr 18, 2004 | 10:04 PM
When you have done a simple thing like the TB bypass and have not drained the system, the easiest way is to let the engine get to operating temperature and then crack open each of the bleeder screws until only a solid stream of coolant comes out.
If you are doing more than that, there is a drain and refill procedure on my Tech Page.
HectorM52
Jul 30, 2017 11:46 AM
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
warmeck
May 1, 2015 11:30 AM
RedLineRev
Jan 23, 2003 03:51 PM
