throttle body bypass
Old Mar 14, 2005 | 03:35 PM
Adam E's Avatar
apparently i am stupid because ive been looking at shoebox's how-to for the throttle body bypass and then going out and looking at my car and still cant quite figure this out. if im standing at the front of the car...i see a hose going into the throttle body on the right hand side and i see the other hose that goes to the metal steam pipe. (well the one with the arrows on it in the how-to picture) im not exactly sure if im looking at the right things...i havent taken anything apart yet because its really cold outside and uncomfortable to work, so perhaps it will be easier once i take the intake tube off. is the hose i see on the right hand side supposed to be the one that connects to the steam pipe? anyone have any different pictures of this so perhaps my dumb self can comprehend this?
thanks,
adam
Old Mar 14, 2005 | 03:53 PM
1SlowFormula's Avatar
Re: throttle body bypass
Yes, the one that goes from the top left (standing in front of the car) of the radiator going to the bottom right of the TB, will be the one that gets connected to the steam pipe on the left of the TB..
The little elbow piece that currently conects the steam pipe to the bottom left of the TB will be removed and not reused...
Old Mar 14, 2005 | 05:33 PM
What year is your car? 93/94 have one hose configuration, 95-97 have a different one. Steam pipe goes directly to the radiator in the 93/94 cars, not to the TB.
Old Mar 14, 2005 | 07:52 PM
Adam E's Avatar
so what would that mean exactly? sorry to sound stupid...just am when it comes to this topic apparently.
Old Mar 14, 2005 | 08:01 PM
The question is simple, what year car do you have?
The reason for asking is because there is different routing for different years, you mentioned Shoebox's instructions in your first post and I assumed it is for a 95 or new car, but like Injuneer pointed out we don't know what year you have, and 93-94 car were different from 95-97 in regards to the routing of the tubes.
Old Mar 14, 2005 | 08:07 PM
pHEnomIC's Avatar
I need to do it on my car this spring. I know how to do it but will i lose a lot of coolant? I want to minimize that because i dont feel like buying anymore coolant. I flushed it when i got my car and had a water pump leak later so i had to buy some more. Can ai do anything to minimize coolant loss?
Old Mar 14, 2005 | 08:12 PM
Adam E's Avatar
my apologies...the car is a 94.
Old Mar 14, 2005 | 09:00 PM
TMorgan800's Avatar
Anyone actually DYNO'd any real gains from this mod. It seems so easy and silly to do, but what if any is the REAL benefit? Butt dyno or Real dyno anyone felt a diff???
Also, speaking of lowering Intake air charge temps.. anyone thought of Cryogenically Cooling the Upper-Intake manifold? I saw this CRYO system thing in the summit catalog. It looks like its for Imports but seems basically universal.. " includes 3" intake adapter to cool incoming air ..etc"..
Sounds like they are on to something..similar to NOS..
Just a thought...
--Troy
Old Mar 14, 2005 | 09:06 PM
unvc92camarors's Avatar
Just a thought...
--Troy
i think ws6.com got 6hp on the dyno
that is iirc
Old Mar 14, 2005 | 09:08 PM
v8pwrdz28's Avatar
http://www.ws6.com/mod-8.htm
Old Mar 15, 2005 | 01:37 PM
That helps. (You might want to add a "signature" with basic info like the year of your car, trans type and any major mods, to help people answer your tech questions).
You pull the hose off the drivers side throttle body connector, and the hose off the passenger side throttle body connector, and use a 3/8" brass barbed hose connection, and two clamps to connect the two hoses together.
Its always a good idea to drain some of the coolant out of the system, using the drain valve at the bottom of the radiator. Just enough to get it below the level of the throttle body. In addition to minimizing the replacement coolant required, it minimizes the risk of dumping coolant on the Opti. When you are done, put the coolant you drained back in the system, and follow the required steps to bleed air from the system.
HectorM52
Jul 30, 2017 11:46 AM
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
warmeck
May 1, 2015 11:30 AM
RedLineRev
Jan 23, 2003 03:51 PM
