Cruise intermittently not working?
Old Jul 2, 2003 | 05:47 PM
JSK333's Avatar
I have an odd problem.
Sometimes my cruise control will not work. When I push the button, nothing happens. And if this happens, it definitely won't work until the car is shut off and turned on again at a later time.
When it works, it works. It'll work until the car is shut off.
This seems to happen maybe 1 out of 10 times I try to use the cruise.
Any ideas?
Old Jul 2, 2003 | 07:05 PM
Janny's Avatar
Mine does this too. I think it is because I may have messed the wires a bit when I took the box off with the RR install.
Old Jul 2, 2003 | 08:46 PM
JSK333's Avatar
Where exactly do all the respective wires run for the cruise system? Anyone have a diagram (Rob)?
Old Jul 2, 2003 | 08:48 PM
QCKZ28's Avatar
i took my cruise off (wt reduction) still have the box if anyones interested PM me.
Old Jul 2, 2003 | 09:26 PM
InGodITrust's Avatar
Your problem could also lie in the sensors (or whatever they are called) on your brake and clutch. IE. when you tap your brake or clutch to kick out of cruise. If these are set too fine your cruise will not always work!! <----- according to the Chilton Manual!
Old Jul 2, 2003 | 11:05 PM
Z95m6's Avatar
mine does this too sometimes. All i have to do is shut it off and turn it on and then it works. It does it rarely but it does do it.
Old Jul 3, 2003 | 10:07 AM
94GreenZ28's Avatar
I have the same problem too. My cruise would work sometimes now it doesn't work at all. Does anyone know any test you can do with a voltmeter?
Old Jul 4, 2003 | 12:40 AM
94GreenZ28's Avatar
We'll I just found out my problem. While trying to set my cruise I lifted up my clutch pedal and it worked.
Red Hawk 94
Mar 18, 2019 04:03 PM
97Z28Muscle
Feb 6, 2015 10:44 PM
jayblev95
Jan 6, 2015 11:52 AM
Collector Car
Jan 5, 2015 10:58 AM
Injuneer
Dec 15, 2014 09:36 AM
