Throttle body Air Foil
Old Apr 25, 2013 | 07:03 AM
SROACH's Avatar
I just purchased a throttle body air foil from ebay! I am I going to notice a difference in hp??
Old Apr 25, 2013 | 09:59 AM
PWR SHFT's Avatar
Re: Throttle body Air Foil
Not really. GM HiTech just did a dyno test and saw a few HP. I have one. Cant hurt.
Old Apr 25, 2013 | 10:37 AM
KW Baraka's Avatar
Agreed. You will not notice any performance gain.
Maybe 3 to 5 HP.......again, not enough to notice.
KW
Old Apr 25, 2013 | 04:46 PM
Dyno test of an air foil on an LT1:
Drivetrain Modifications #4
2.4 peak HP
Dyno tests of other popular mods:
WS6.COM LT1 Trans Am
Old Apr 26, 2013 | 12:53 AM
popo8's Avatar
please make sure u secure the screw/s so it does not back out.
A member on corvette forum had one spit out its screw and it went in to join a piston for a lil while... it was like metal hamburger in there.
Larry (Popo8) Co-owner
LTXtech.com
Old Apr 30, 2013 | 09:40 PM
SROACH's Avatar
Oh thanks everybody! I tighten it down good but I think I will be rechecking it before I start driving it again. Thanks popo8!!
Old Apr 30, 2013 | 10:50 PM
popo8's Avatar
My pleasure man. Id hate to see anything bad happen.
LTXtech.com
Old May 9, 2013 | 09:15 AM
SROACH's Avatar
Well I re tighten it really good. I think I stripped it. It shouldn't back out now.
Old May 9, 2013 | 09:52 AM
94Form's Avatar
lol what?
Old May 9, 2013 | 10:47 AM
KW Baraka's Avatar
Well, I hope you DIDN'T strip it......because if you did, it won't hold at all.......
KW
Old May 9, 2013 | 01:31 PM
ACE1252's Avatar
Yeah...if you stripped it, then best to remove it and get another one. You also need to make sure that shavings from the threads don't get into the engine(if possible). That may involve taking off the throttle body and removing the airfoil on a workbench. Then you can turn the throttle body upside down to make sure any metal gets removed from it.
Next time, use some blue thread locker on the threads and snug it up tight(no He-Man like force needed).
Old May 9, 2013 | 09:58 PM
RamAir95TA's Avatar
At this point it's probably a good idea to remove it, throw it away, and never buy a new one again.
Old May 10, 2013 | 12:07 AM
popo8's Avatar
im hoping he mean he stripped the end of the screw....
LTXtech.com
Old May 10, 2013 | 05:34 AM
Lt1son's Avatar
Old May 11, 2013 | 10:07 AM
SROACH's Avatar
No just the head. I can't get it to back out. I over tighten it. I wanted to put some thread lock on it. I'm such a amateur!
