throttle body
Old Nov 8, 2006 | 11:51 AM
96camaroz281988's Avatar
throttle body
what is the stock size throttle body for a 96 z28 48mm or 52mm.
Old Nov 8, 2006 | 11:58 AM
The throttle body bores are 48mm. The holes in the intake manifold are 52mm.
Old Nov 8, 2006 | 12:11 PM
z28trick's Avatar
so would a 52 mm throttle body on a stock car help?
Old Nov 8, 2006 | 02:15 PM
cbcs's Avatar
i wouldnt imagine so. not a noticeable difference anyways, it would help if you were using forced air intake or had a pretty sick intake. just my thoughts
Old Nov 8, 2006 | 07:01 PM
razor02097's Avatar
a larger throttlebody may actually hurt power due to the lower velocity of the incoming air.
Old Nov 8, 2006 | 07:40 PM
2000GTP's Avatar
No, not really, but if you do a heads/cam upgrade, then it is a different story.
Old Nov 8, 2006 | 08:21 PM
RedsTA's Avatar
I dont think so. I first went to a ported TB and could feel a small difference, nothing amazing, just better repsonse. Then went to a 58mm tb and could definitely tell a difference. Idle was healthier, throttle response was great, I would recommend using a larger throttle body.
I read a lot of opinions before i bought mine, it seems that people are pretty much split on the idea. Just try it, if you dont think it helped. you wont have a problem selling it most likely to make your money back.
Old Nov 8, 2006 | 08:27 PM
MeanGreen97Z's Avatar
I installed a ported 52mm TB on my 93 Z28. I had a hooker catback, cai, ory, and a reprogrammed chip. I got 5rwhp and 3ft lbs of torque on the dyno from one on a basically stock car.
Old Nov 8, 2006 | 10:16 PM
razor02097's Avatar
The money would be better spent on something other then messing with the throttlebody. Unless you have an upgraded top end and valvetrain that flows more air a stock LT1 won't benefit much from a bigger throttle body
Oh and there is a difference between "feeling faster" and being faster. Feeling faster means spending money on a part or parts that doesn't add much real power but the brain tricks you into thinking it is faster.
Old Nov 8, 2006 | 10:46 PM
WonQuickZ28's Avatar
48mm is stock size on all LT1 throttle bodies.
Old Nov 9, 2006 | 07:36 AM
rskrause's Avatar
Moderator
Very little difference in power on a stock car. You may feel a difference in throttle response as a larger TB will increase flow more with the same change in the angle of the throttle plates.
Rich
Old Nov 9, 2006 | 10:42 AM
No. The plenum effectively decouples the throttle body from the intake process. It's just a "valve" that can be opened and closed. It not like a carb, where velocity is important to the fuel mix.
Old Nov 10, 2006 | 12:56 AM
RedsTA's Avatar
It wont benefit much from a bigger throttle body, but it will benefit from it in my opinion. My car feels a lot healthier with it on there. Get one for a good price and decide for yourself like i said.
And yeah theres a difference between feeling faster and being faster. With a bigger throttle body, i wont say ive proven it myself, but i believe it will be faster and feels faster for sure. Guess its just a mod that doesnt have true numbers gained ironed out yet.
Old Nov 10, 2006 | 06:46 AM
rskrause's Avatar
Moderator
There is a gain in the range of 3-5 rwhp on the chassis dyno.
Rich
Old Nov 10, 2006 | 11:20 AM
RedsTA's Avatar
Rich
Was that on a stock car? Slightly modded? Any idea??
