throttle body
Old Jul 23, 2006 | 08:52 PM
1BLK97CONV's Avatar
throttle body
put a holley 58mm t-b on my lt1 and now it won't idle down unless i tap the gas. the throttle cable seems to work good no binding.is there something else that needs to be changed when changing the t-b.or do i just need to adjust something? if so what?
Old Jul 23, 2006 | 10:32 PM
frankthetank078's Avatar
Re: throttle body
maybe to much air going in at idle?...that T/B doesnt have much to support so it isnt like ur engine is feening air
Old Jul 24, 2006 | 12:29 AM
Dave88LX's Avatar
Re: throttle body
Did you check the TPS voltage? Do you have a way to check the IAC position?
Read this thread:
http://web.camaross.com/forums/showthread.php?t=459834
Looking at your signature, I don't think you needed a 58mm throttle body, did you?
Old Jul 24, 2006 | 09:02 AM
Re: throttle body
Common problem:
http://camaross.com/forums/showthread.php?t=462614
Old Jul 24, 2006 | 04:49 PM
1BLK97CONV's Avatar
Re: throttle body
thanks you're right the spring is a wimp.going tighter worked, the blades looked good. again thank you
Potent77
Mar 16, 2022 12:13 AM
Peytons'z
May 6, 2021 09:25 AM
HectorM52
Jul 30, 2017 11:46 AM
warmeck
May 1, 2015 11:30 AM
4586
Parts Wanted
Mar 17, 2015 11:24 PM
