Thread sealant?
Old Sep 10, 2008 | 05:36 PM
96 Z-Ragtop's Avatar
Thread sealant?
Hey guys, I am going to be putting my new heads ( AFR 195 Elimators-old style ) on the 355 tomorrow night. Being a newb to engine building I have read some horror stories about head stud leaking. Being that I am going with ARP head bolts do I need to use a sealant with bolts? Or not?
If so what do you guys recommend?
Old Sep 10, 2008 | 05:55 PM
95Blackhawk's Avatar
I used ARP thread sealant and every single one of my threads leaked. Ultimately, I had to clean each one and use teflon tape. All is now good.
I suggest teflon tape because that is not the first time it has worked for me.
Old Sep 10, 2008 | 06:54 PM
camaro1fastz28's Avatar
i used the liquid teflon paste and have no promblems
Old Sep 10, 2008 | 07:00 PM
Yes, you want to use sealant on the bolts. Permatex high temp thread sealant is what I have been using.
Old Sep 10, 2008 | 08:08 PM
mad95z's Avatar
Permatex #80632 thread sealing paste works great.
Old Sep 11, 2008 | 05:33 AM
94zgreenmachine's Avatar
The bolts pass into coolant passages. I never had a problem using the ARP sealant. I wanted to try the permatex stuff this time around but my local Autozone didn't have it so I used my ARP sealant, again.
Old Nov 19, 2008 | 08:32 PM
DirtyDaveW's Avatar
ARP site has specific torque levels, differentiating between 30wt oil and ARP lube. The differences are large (ex: 30wt = 65ft lbs, ARP Lube = 45ft lbs for a given ARP bolt, not necessarily for our LT1's). My question is, since we have to seal the bolts, can we really use oil OR ARP lube? I would think not. So, what do we torque them to?
THanks,
DAve
Old Nov 19, 2008 | 08:56 PM
Green96Z's Avatar
THanks,
DAve
You put sealant on the threads, and then oil/lube on the UNDERSIDE of the bolt head and washer, not on the threads. Or in the case of the OP, under the nuts. I went with bolts and have no leaks.
magman
Apr 15, 2016 03:08 AM
n2oblkz
Oct 22, 2015 02:31 PM
Double aught
Oct 2, 2015 11:29 PM
Formula Steve
Sep 19, 2015 08:48 PM
sleeperZ96BT
Sep 10, 2015 08:01 AM
