Thread and pitch of bolts to mount LT1 to engine stand?
Old Mar 24, 2008 | 07:16 PM
MeanGreen97Z's Avatar
Anyone know these? I'm bolting the engine to a X pattern engine stand so I can rotate that bad boy. Anyone know the bolt size?
Old Mar 24, 2008 | 07:20 PM
cnorton's Avatar
The bolts that retain the transmission to the back of the block are 3/8 coarse thread (USS, not metric). The thread count is 16 per inch. Thread pitch is not an issue on USS fasteners.
Old Mar 24, 2008 | 07:21 PM
ss.slp.ls1's Avatar
Good question...I'd like to know the locaton of the mounting bolts as well.
Old Mar 24, 2008 | 07:24 PM
ulakovic22's Avatar
You can use any of the bellhousing holes to mount to. I use the bottom two and then two up top at about 11 and 1.......maybe it's 10 and 2, but you get the idea. I think you should be good with 4" bolts...don't forget washers.
Old Sep 2, 2008 | 02:02 PM
KYWes's Avatar
For anyone still checking this topic I found I need 2.5" bolts to hold tight against the engine with my Harbor Freight purchased engine stand. 3/8's coarse is the size that fits my LT1 engine.
Old Sep 2, 2008 | 03:33 PM
<Puck>'s Avatar
3/8 x 16 course, 2 1/2" long.
Get stainless or grade 8, not the cheapo 30 cents each ones.
edit:: oops old thread...
rocketman051894
Jan 30, 2015 03:23 PM
NorthPoleDev
Dec 31, 2014 03:20 PM
nballisru
Dec 14, 2014 05:01 PM
Not Dave
Dec 11, 2014 06:32 PM
