Lt1 Loud Knock Won't Start Banging
Old Sep 1, 2008 | 12:32 PM
str8rpn's Avatar
My LT1 won't start at this point. After I installed a new pressure plate this all happened. Not sure if its just coincidence. After I reinstalled the tranny and a new poly mount I took it for a ride. It ran mint for about an hour and two 10mph launches. After another 100mph pass It started to hesitate or miss for a second and then pull again while driving home. So I thought it was a rocker too tight or something. After checking the rockers I put it back together and drove it last night for about 10 minutes before I started to get a loud banging when under a load. So I brought it home and left it to look at this morning. I just went out to start it and it just cranks over and bangs A LOT. Could this be a spun bearing, rod knock, broken crank or is something binding with the tranny?
Old Sep 1, 2008 | 03:27 PM
Stl94LT1's Avatar
Is the noise coming from the tranny or engine?
Old Sep 1, 2008 | 07:37 PM
str8rpn's Avatar
im not sure
Old Sep 2, 2008 | 07:46 AM
str8rpn's Avatar
ttt.....anyone? help
Old Sep 2, 2008 | 08:06 AM
Too vague. Your going to have to give more info on the noise and where it is coming from.
Old Sep 2, 2008 | 12:29 PM
str8rpn's Avatar
i cant really tell the car wont run more then a second.
Old Sep 2, 2008 | 03:54 PM
rx8ss's Avatar
Pull your plugs and check for damage and wetness after trying to start. If damaged, enough said. If wet, check compression.
HectorM52
Jul 30, 2017 11:46 AM
bfmv13trivium
Jan 14, 2015 09:57 AM
Jessie4tin
Jan 7, 2015 08:53 AM
jayblev95
Dec 1, 2014 06:55 AM
Dyoung_Z28
Nov 25, 2014 05:26 PM
