Those who did the upgraded the fuel pump with the trap door mod.
Re: Those who did the upgraded the fuel pump with the trap door mod.
done mine today used offset tin snips, the trap door went fine but i could not get the damn pump out. ended up droping the tank any way, what a PITA. this was on my 89 is it the same setup as the 4th gens?
Wish these guides were around 3 years ago when I did mine. I used a huge cutoff wheel with sparks everywhere. My buddy was behind the garage with 911 on speed dial.
I marked it out and drilled a 1/2 or smaller hole in one corner and used a pair of offset sheetmetal sheers. I have a big set of specialized sheet metal sheers from when I used to work in HVAC and they worked perfectly. I had it very cleanly cutout in like a minute or two, that really is an easy and very safe method. I would not feel safe grinding away just 1" above that gastank!
I went to Home Depot, but the sheet metal they had was way too thin. What gauge sheet metal do you recommend to make a cover?
BTW, using metal snips was a freakin' PITA!
