Those with March LT1 underdrive pulleys...What length belt?
Old Jan 24, 2006 | 10:50 AM
wrd1972's Avatar
Got some used LT1 March underdrive pulleys.
I have the main pulley and the altonator pulley.
I know I need a shorter belt but I dont know what size.
Who knows the right length?
Old Jan 24, 2006 | 11:35 AM
fastchevy's Avatar
Re: Those with March LT1 underdrive pulleys...What length belt?
I need to know this info as well!
Old Jan 24, 2006 | 12:12 PM
wrd1972's Avatar
If someone can give me the circumfrence of the stock crank and ALT pulley I can do the math.
Old Jan 24, 2006 | 01:21 PM
Zeueses 97 RamAir's Avatar
25 inch belt
Old Jan 24, 2006 | 02:04 PM
Mtrhds94Z's Avatar
Originally Posted by Zeueses 97 RamAir
25 inch belt
You're kidding right?
I don't know what size he needs but do know it can't be 25 inch..
It has to be close to 61 or so..
Old Jan 24, 2006 | 03:27 PM
wrd1972's Avatar
I definitely agree it must be longer.
He might be referring to if you pull it taught it would measure 50"
Old Jan 24, 2006 | 03:38 PM
RickS's Avatar
i have the march under drive crank/ overdrive alternator pullies, and my car has no ac. i ended up swapping belts at the store for a while till i just took a piece of string and routed it the way the belt goes and took a little off for the tensioner.
the one i use came out to be "21mm X 1485mm" ~about 58.46 inches
this is with 1le AC delete pully and Overdrive alternator
RedLineRev
Jan 23, 2003 03:51 PM
Speeds8erM-1
Aug 20, 2002 09:12 PM
Speeds8erM-1
Aug 15, 2002 10:07 PM
Speeds8erM-1
Aug 13, 2002 10:24 PM
Speeds8erM-1
Jul 28, 2002 06:18 PM
