Those with AS&M or RK sport headers...I need your help.
Old Jul 29, 2006 | 06:00 PM
wrd1972's Avatar
Got a question about the right side (passenger) collector. As I am sure you all already know 2 of the 3 bolts have good access, however the lower passenger side bolt is a bitch to deal with cause the k-member blocks all access. I just found that the bolts have loosened causing major exhaust leak.
There is no way to get a tool on the nut on the back side (header side) and you cant get a socket on the bolt (short pipe) because of the bend of the short pipe is in the way.
What I have done in the past is use an Allen head bolt, this way I can get a ball Allen wrench on it. On the back side I used a serrated lock washer so I dont have to get a tool on the nut.
My question, does anyone have neat tricks for this very hard to get to bolt.
Old Jul 30, 2006 | 01:48 PM
Fastbird93's Avatar
Re: Those with AS&M or RK sport headers...I need your help.
Use an extension and a crow's foot attachment to hold the bolt from the backside, and tighten the nut using whatever your hearts desire. Has worked for me every time and no leaks.
Old Jul 30, 2006 | 02:04 PM
TechnoThief's Avatar
I had nuts welded to the back side of the flange so I would never have to worry about it. I'll get picture so you can see.
Old Jul 30, 2006 | 04:42 PM
wrd1972's Avatar
This sounds like a good idea.
I am also considering these:
http://store.summitracing.com/egnsea...1&autoview=sku
The nuts have that long leg which will make it a lot easier. Im not sure if I can use the locking bolt in this problem area, however the locking fasteners will work for the other two areas.
Old Jul 30, 2006 | 04:45 PM
romoranger's Avatar
i had to get it welded together. i did the nut welded on but then the bolt would back out. weld that thing and forget about it. makes taking it out a real pain though.
Old Jul 30, 2006 | 05:21 PM
wrd1972's Avatar
I definitely am not in favor of welding pipes, as soon as I do I will have to remove it for somthing.
I want rely on fasteners at this point. The stage 8 collector bolts are looking pretty good.
Old Jul 30, 2006 | 11:10 PM
kyle97's Avatar
That bolt is in a really tough spot. I used the stage 8 collector bolts ( they have that tabbed nut so that you dont need a wrench on the back). and ground down a 14mm socket at an angle to use on the bolt. Even with my setup it's still difficult to get to but it's at least possible.
Old Jul 31, 2006 | 07:42 AM
wrd1972's Avatar
I have the stage 8 collector bolts on the way. That sounds like the best way.
David Dempsey
Mar 12, 2016 12:42 AM
CARiD
Sep 30, 2015 05:44 AM
surreybrad
Sep 29, 2015 09:00 PM
CARiD
Sep 7, 2015 08:21 AM
GusarskiSS
Exhaust System
Sep 2, 2015 03:51 PM
