Those with !Air inside please!
Old Dec 29, 2003 | 12:40 PM
cocheese's Avatar
Ok, i am about to remove the air pump and hoses and such, and I wanted to know what you guys used to cap or plug the hole on your CAI where the hose was. I found that I need to use 22mm plugs for my manifold holes, but it didn't say what to use for the CAI hole. Thanks guys,
Ryan
Old Dec 29, 2003 | 12:47 PM
1msfyter's Avatar
On my SLP CAI I moved my IAT to the hole for the air pump. I put a K&N mini foilter on the hose for the airpump. Later I completely removed all the air pump crap. What you can use is a rubber cap(i used a 1") It is actually a chair leg rubber cap.
http://www.bealer.org/iatrelocate.jpg
Old Dec 29, 2003 | 12:50 PM
Jag's Avatar
Jag
And what does this do for you? Any Horsepower gains?
Old Dec 29, 2003 | 01:03 PM
LWillmann's Avatar
No horsepower gains. Just clears up the engine bay a little.
Old Dec 29, 2003 | 01:18 PM
cocheese's Avatar
Also, what is the best way to remove the pipes on the manifold? I soaked them in WD-40 overnight, and I'm not sure the best way to remove them. Thanks again,
Ryan
Old Dec 29, 2003 | 01:24 PM
1msfyter's Avatar
My air tubes on the exhaust mainfolds unbolted right away. I would soak overnight they should come right off.
Old Dec 29, 2003 | 01:33 PM
ROWYCO's Avatar
Has anyone removed the hard line that goes underneath the engine? If so, how did you do it?
Old Dec 29, 2003 | 01:36 PM
AsianSensation's Avatar
I used a Dremel and cut it in different places. You can see it's in pieces.
http://www.97ta.com/lt4/lt501.jpg
I used a 3/4" vacuum cap on my Moroso.
http://www.97ta.com/useless_folder/AIRplug.jpg
ibanez6rg's Avatar
I wasn't able to do it. I don't know how people get in there. I'm gonna do it during my heads swap, should be easy then.
Old Dec 29, 2003 | 01:47 PM
cocheese's Avatar
Thanks alot guys, I appreciate all your replies.
Ryan
Old Dec 29, 2003 | 03:37 PM
RMC's Avatar
RMC
Oh man I set to that one day because I'd had about enough of that thing being in my way. Well it turned out I was a little short handed on tools but was too deep to turn back.
I ended up bending the tubes back and forth and back and forth by hand for half the night until they got brittle and broke. That was a free muscle workout I wish I didn't get.
Just make sure you have some cutting tool or you will be there a long time trying to get it out. I thought if I broke it in the bottom center I could bend it around enough to get it out. That was not the case. I had to break it in several more places.. by the bending method described above no less. I wish that on no one, so find something small that you can get in there to cut it all up for removal.
Other than that I like having it out of my way for the times I have to get in and reach plug wires or whatever.
Old Dec 29, 2003 | 09:49 PM
revtime's Avatar
I have come to the conclusion that a dremel is a required tool for your box.
A dremel with a cutoff wheel zipped right through that line, I had it out in like 5 minutes.
Dremels come in handy everywhere.
Old Jan 3, 2004 | 11:50 PM
WhoomWhaatWhaah's Avatar
get some green handle shears and cut close to the oil pan and It should come right out, It's also attached to the air pump bracket which u can toss.
Biggiebound
Apr 23, 2015 08:50 AM
carl.froehlich
Mar 13, 2015 12:38 AM
rjc1629
Jan 27, 2015 10:46 AM
95chwagon
Jan 13, 2015 09:19 PM
squarehead
Nov 21, 2014 08:02 PM
