those with 4.10's i need advice
Old Mar 12, 2004 | 11:05 PM
maddog89's Avatar
m6 and 4.10's,,,,,,,,,,i cant hook for **** in 1st does anybody find it easier to just start in 2nd? im running 275 35' 18's in the rear,,,,and ya i know if i go with a DR' id hook but i dont wanna resort to that,,,,,,,,,,,,,,,,,,,,,,,,,,,,thanks
Old Mar 12, 2004 | 11:07 PM
jcolez28's Avatar
DRs is the only way you will hook. Isnt there a company that makes 18s.
Old Mar 12, 2004 | 11:09 PM
maddog89's Avatar
i need to do something i cant use full throttle till im into 3rd gear i just spin in 1st and second
Old Mar 12, 2004 | 11:58 PM
97Camaro007's Avatar
That's because you don't have any sidewalls.....you need to put different tires when you are racing.....
Michael
Old Mar 13, 2004 | 03:48 AM
1BigBird3's Avatar
Maddog89,
Was curious what kind of clutch/pressure plate you are using.
Thanks.
Ruben F.
Old Mar 13, 2004 | 08:44 AM
Grease's Avatar
I usually drag race with drag radials but one night I went to the track with street tires and was running 13.5s @ 113mph. On one run I tried starting up in second gear and ran 14.23 @ 109mph.
When you have 4.10s and street tires you have to learn how to roll into the throttle. But to save yourself from alot of frustrations, just get drag radials.
David Dempsey
Mar 12, 2016 12:42 AM
WobblySausage
Oct 7, 2015 02:44 PM
WobblySausage
Oct 7, 2015 10:09 AM
68camaroboltz
Oct 5, 2015 01:46 PM
