Think i broke iac, maybe not
I was planning on doing and intake gasket leak repair and i took my tb apart for cleaning. I accidentally pulled the pintle out of the iac. I think i broke it but it is possible i didn't. Does anyone know if i just screwed it back in and pushed it down, will that fix it? I cant tell any other way to service it but i sure don't want to buy a new one, 50$ at autozone and i am tired of buying new sensors for stupid stuff. Already had to buy tps and coolant temp sensor.
Re: Think i broke iac, maybe not
How does the car run in open loop? When mine was going out, the car would start, and then die, and it acted like a carbed car when starting in anything less than 70' outside. I'd have to give it gas to make it idle, etc...
I put thye car back together and it seems to run ok... Idle seems a little high when not in gear. Is it normal to run a little higher when the whole tb and idle air chamber has been cleaned out? Seems to be just right when in gear though, havent driven it much.
I didn't run it long. Tach said a little under 1500 so i think that should be alright. Don't remember exact number just seemed a little higher than normal to me. I didnt let it warm up either though.
Well i drove it and the idle seemed somewhat high for a few blocks then it was normal when i arrived at my destination. In gear was ~700 on the tach and out of gear was like one bar higher. The pcm probably just needed to adjust. I am not sure if i broke it or not so i dont want to buy a new one if i dont need to. I guess ill drive it a few more days and see what is going on. If i need a new one, then i will get a new one.
95z_28_camaro_4_Ivan
Oct 3, 2015 07:27 PM
