They say My engine is FINISHED!
Old May 23, 2003 | 08:44 AM
  #61
thefox1's Avatar
Originally posted by Metaldrgn
No, that does not mean your engine is dead. Don't listen to them. The quality of the sound can make it seem like something entirly different. My sound card is stuck in a reverb mode so I couldn't really hear it as well as I wanted to, but one thing I think I might of heard was a hiss. That means a vacuum line might have came loose, but that won't do anything with the oil pump. You could have the oil pressure professionally tested (well at like pep boys or someone like that) with a different, plugin gauge. Get a screwdriver and place the metal tip on the top of the engine where the heads are by a bolt , put your ear on the big plastic end and and rev it alittle. hear any knocking or pinging? Is it loud? spun cam bearings wound not make the oil pressure drop to 0 though. You cant check it unless you take it completly apart for spun cam bearings
Well, at this point I'm going to wait for the expert to come over next week. But your right, the sound while I was under the hood was off fom the real thing. But it does seem now that it's starting to knock a little while it's cold. If it does need a rebuild I'm starting to think of a cam kit, any suggestions?
Old May 23, 2003 | 08:58 AM
  #62
Metaldrgn's Avatar
It's probably knocking because the rings are grabbing the cylinder walls and hitting the skirts or something (because of the lack of oil). You are still having that oil pressure problem right?
Old May 23, 2003 | 09:01 AM
  #63
Metaldrgn's Avatar
so is that a loud scraping sound I am hearing? (damn my sound card)
Is it smoking?
Old May 23, 2003 | 09:06 AM
  #64
94SLUG's Avatar
It does not matter if all the vaccums are off that thing is BANGING bad.
Old May 23, 2003 | 09:30 AM
  #65
Metaldrgn's Avatar
ok, fixed my sound card... Doesn't really sound to different now. Does the sound change when you rev it, I couldn't really tell.
Old May 23, 2003 | 09:47 AM
  #66
Metaldrgn's Avatar
yea, wouldn't really start it again until that guy gets there.
Old May 23, 2003 | 09:50 AM
  #67
Metaldrgn's Avatar
Something that I didn't know till now (books didn't mention this) is that the oil pressure goes through the gallies and if the bearing are spun it won't let the oil through and you wouldn't get any pressure to the sending unit. My stepdad told me that so it looks like I was wrong :/
  #68
thefox1's Avatar
Is it smoking?
Nop, it's not burning oil. The oil pressure is low (as per the gauge) but should be enough. I'm told it dosen't drop until it's hot, and the idea on the bearings is what I got from another garagist the other day. But until someone hears it live, I'll just have to wait until tuesday.
Noer
Feb 28, 2015 11:29 AM
Collector Car
Jan 5, 2015 10:58 AM
cmdeshon
Dec 12, 2014 10:51 PM
