They say My engine is FINISHED!
Originally posted by thefox1
Well, I finally have the jsut of it now that I'm home. Engine really runs perfectly while cold, but, the oil gauge takes about 3-5 to go from 0-275, and then it stays half way. Now from experience on these cars I know that when there cold thje oil pressure gauge should go up to 3/4 and stay there until norm operating temp then drop at idle. So at this point, could it be a weak pump? I'll also have a look at what trey told me about the pickup.
nop, not to late. But if the pump is weak at that point, would it also be possble that it's not pumping like it should be (even though it's hooked up dirrectly to the crank)? Bc, even at rpm it does no go where it should.
lol you can build a faster one than that for less than $2000 if you know how to do it.
As long as you are pulling about 10psi for every 1000 rpms, you should be good. That's the bare minimun though. It could be loose. If it is I would hurry up and get it fixed before it really does some damage because if it is just loose there is a chance that someone can just rebolt it in place and you would be fine.
I am talking about the driveshaft for it. The pickup was only mentioned because if it comes out of the oil and sucks air, your oil pressure meter will read 0.
I just got my book on LT1/LT4 rebuilding and I will scan a picture tomorrow (I have to leave for work in like 2 mins) if I can find one of what I am talking about.
I am thinking Cam bearings or the main bearings. My friends 87 350TPI is having the same problem.
If the pickup fell off, then 0 oil pressure will register when the starts up, right? Or if it did, it would drop almost immediately, right?
For those of you who migh be able to tell a little bit more with the sound here's a clip from tonight of it running while cold.
http://www.techvien.com/MOV00001.MPG
Originally posted by Zepher
Sounds like the bearings.
It's pumping oil but it's losing pressure.
My friends car sounds just like that.
No, that does not mean your engine is dead. Don't listen to them. The quality of the sound can make it seem like something entirly different. My sound card is stuck in a reverb mode so I couldn't really hear it as well as I wanted to, but one thing I think I might of heard was a hiss. That means a vacuum line might have came loose, but that won't do anything with the oil pump. You could have the oil pressure professionally tested (well at like pep boys or someone like that) with a different, plugin gauge. Get a screwdriver and place the metal tip on the top of the engine where the heads are by a bolt , put your ear on the big plastic end and and rev it alittle. hear any knocking or pinging? Is it loud? spun cam bearings wound not make the oil pressure drop to 0 though. You cant check it unless you take it completly apart for spun cam bearings
its not a vac leak
I didn't say a vacuum leak was causing this problem. I said I heard something that could be a vacuum leak. Sometime a vacuum leak though can cause an engine to heat up a lot. At least on Gen 1's they could.
