They say My engine is FINISHED!
Originally posted by Metaldrgn
What bearing are you talking about? I don't think the oil pump even has bearings. It can't be the canshaft bearings or he'd be in way more trouble than that. When's the last time you checked the oil level. If NO oil or a very low amount is getting to the pump it will go down to 0.
main/rod bearings
in any event- i have to disagree with grip in that if his bearings "just randomly went" (or spun) it would be knocking all the time. When he changed the oil and started it up it wasn't knocking.
yea, but why would his oil pressure go down to 0 then? When are you hearing this? what rpm range? Does it do it when you are in a certain gear more than another? does it ping when you are in prk/neutral?
Originally posted by thefox1
The awnseres to those questions I'll have tonigh in a couples of hours when I get home and see for myself. My father (who towed the car home) started and said it ran fine (while cold, he did not let heat up) and said he could not hear any pining at all. That's why I don't see how it could be that bad if it runs so smooth while it's cold. That means that there's something that when it takes expansion with the heat is either broken or not calibrated properly? Also, I noticed on monday after opening the hood that on the left side the 2nd exhaust pipe coming out from the engine (on the driver side starting from the back) was red hot, could it be something with that exhaust valve or piston there?
Well, I finally have the jsut of it now that I'm home. Engine really runs perfectly while cold, but, the oil gauge takes about 3-5 to go from 0-275, and then it stays half way. Now from experience on these cars I know that when there cold thje oil pressure gauge should go up to 3/4 and stay there until norm operating temp then drop at idle. So at this point, could it be a weak pump? I'll also have a look at what trey told me about the pickup.
If it where me, and the car was not knocking, pinging, taping or burning oil i would look other places. Unless you wanna rebuild for a mod motor
. . Bearings or a bearing does not mean your oil pressure is going to be low every time. A real thick oil will hold good oil pressure in many situations. Than again if your oil filter was so pluged it stoped oil pressure
I would think somthing is damaged in the pump or other places. Wait till you get the car back crank it up and see for yourself. It could be many things at this point.
EDIT I see I was 8min to late and you already posted, damn phone calls. My car when stock ran low oil pressure for 20k idle only, at WOT it was fine.
I would think somthing is damaged in the pump or other places. Wait till you get the car back crank it up and see for yourself. It could be many things at this point.EDIT I see I was 8min to late and you already posted, damn phone calls. My car when stock ran low oil pressure for 20k idle only, at WOT it was fine.
I'M IN LUCK!!!!!!!! My father knows the best guy at the GM plant in ste-therese who use to solve factory defects with our engines, sometimes only by listening to them. He said he would pass by next week to have a look at my engine.
"pickup"? Is that something to do with the oil pump?
Originally posted by treyZ28
I had the same symptoms when my pickup came loose. oil thins out, inaccurate guage. i had like 30lbs of pressure though so i was fine...
just bang the pan like i said before
