They DO exist!! (MSD Opti)
Re: They DO exist!! (MSD Opti)
Nice piece. I'm toying with the idea of buying one of these and removing the cap and rotor and welding an aluminum cover over the optical half to use it as a bulletproof/leakproof cam sensor for the Delteq setup I'm running.
Originally Posted by jamilz28
why is it better then stock?
Hopefully they will be more reliable, and water-resistant.
Originally Posted by Ponyhntr
It's the screw next to where the harness comes out.
I thought that was probably it, but I wasn't sure.Looks like it might be in a spot that will make on-car adjustments difficult
Originally Posted by Taintedz28
quick question, is the opti from MSD water-proof like dynotechs?
Originally Posted by RCF925
So am I right in assuming the MSD Opti for a 94 Z28 comes with Vacuum lines? If so I may buy one.
