these fit???
Old Jun 18, 2003 | 10:01 PM
burnemonm1's Avatar
these fit???
I am looking at some corvette c5 rims and the guy says they have no sensors. the rear tires are 275/40/18's and the fronts are 245/45/17's will these be clearing everything ok?
thanks
Old Jun 18, 2003 | 10:06 PM
The 275/40-18 will be about 1" larger in diameter than the stock tires, and throw your speedo off by 4%. The better choice would be a 275/35 or a 285/35. The larger diameter will raise the back of your car 1/2" more off the ground, and push the tire 1/2" further up into the wheel well, which generally isn't a problem. The larger diameter will also be like lowering the numerical rear axle ratio by 4%.
Whether the tires will rub will be determined more by the backspacing of the wheels than the tire size. Some of the 18" C5 wheels have a 65mm offset, which puts the wheel a little too deep into the wheel well.
Old Jun 19, 2003 | 05:39 AM
burnemonm1's Avatar
ttt
Old Jun 19, 2003 | 03:02 PM
burnemonm1's Avatar
still looking for someone that has or has seen these on an F-bod thanks
Old Jun 19, 2003 | 10:29 PM
burnemonm1's Avatar
any help at all... calling shoebox
Apr 3, 2015 10:54 AM
mschmidt33
Mar 15, 2015 07:20 PM
Jan 23, 2015 01:13 PM
TheGreenZ28
Exhaust System
Dec 6, 2014 10:23 PM
Camaro_Eric
Aug 8, 2002 12:21 PM
