Thermostat-What's the truth???
Old Apr 13, 2005 | 11:17 PM
brians96Z's Avatar
Hello. I had just decided to get a 160 Hypertech Powerstat, to go along with my Power Programmer, but after searching the topic on these forums, I am confused. Is is true or not that a 160 thermo will cause you engine to stay too cool, and increase engine wear? There are so many different opinions on this....I wish someone could tell me for sure. Also would my engine stay in closed loop?
Old Apr 13, 2005 | 11:38 PM
Re: Thermostat-What's the truth???
I have never seen any documented engine wear issues. Closed loop is not an issue as the minimum temp is ~140°.
Old Apr 14, 2005 | 12:17 AM
brians96Z's Avatar
Thanks for the quick reply, Shoebox.
Old Apr 14, 2005 | 12:29 AM
revtime's Avatar
Cause engine wear? No.
In fact my LT1 has had a 160 stat in it for over 100k. It has 156k on it now and I am convinced that part of the great luck with this engine I have had is in part due to it running cooler for most of its life.
And like Shoebox said, it going into closed loop is a non issue.
Old Apr 14, 2005 | 01:11 AM
PurePonyPounder's Avatar
I haven't experienced any premature engine wear on my engine and I've been running without a thermostat closing in on eight years now. You are going to two schools of thought: those who believe its a necessity and those who believe its not.
Johnny
Old Apr 14, 2005 | 08:59 AM
All4Chevy's Avatar
I did notice that when I ran the 160 and the fans on all the time and the temp never went over 170 that when I would take off the oil filler cap there would be drops of water there (condensation I guess) but now I turn the fans off most of the time and let her get up to around 210 and no more water!
Bill
Old Apr 14, 2005 | 09:03 AM
WS Sick's Avatar
The drops of water in the top of the oil cap and or valvecover are normal.
I have had a 160 deg thermostat in an LT1 since 1993 and have had no problems with wear (have had problems with me breaking stuff though...lol)
We don't have extremely cold winters here, but we get below 20 degrees several times and my heater has worked fine when the engine temp reaches normal.
Old Apr 14, 2005 | 11:07 AM
brians96Z's Avatar
Ok, what about gas mileage? Are you guys seeing any difference between a 160 and 180 thermostat?
Old Apr 14, 2005 | 11:08 AM
Antz97ZNJ's Avatar
No engine wear...the car will run cooler, but on a hot day it really wont matter anyway...Never had any problems when I was runnin a hpp/powerstat
Old Apr 14, 2005 | 03:00 PM
Silver's Avatar
I would think your mileage would drop a bit with the cooler engine.
Old Apr 14, 2005 | 03:01 PM
I switch from 160 to the 180 in the coldest months. Never have noticed any real difference in gas mileage.
MDZ28
Exhaust System
Jun 2, 2015 09:48 PM
R@mpage
Apr 20, 2015 10:02 AM
FredM
Exhaust System
Feb 18, 2015 05:37 AM
S. Holley
Jul 20, 2003 12:33 PM
silicuda
Pacific
13
Jun 11, 2003 05:22 PM
