thermostat housing cracked
Old Aug 4, 2005 | 02:54 PM
heitz's Avatar
Anyone ever had this happen to them and did it hurt your opti. I have towels all aroud it but I'm still worried about it. There is some coolant on the ground. If I let the car sit for a couple days and not start it should I have anything to worry about? Thanks
Old Aug 4, 2005 | 05:00 PM
Heatmaker's Avatar
Advanced Member
Re: thermostat housing cracked
That's a problem you want to take car of. Leaking coolant isn't cool.
Depending on were it is exactly I whould put some JB weld (the putty version) on there, it should solve the problem. Has worked well for me in the past.
Old Aug 4, 2005 | 05:37 PM
Replacing the housing seems like the proper thing to do.
Old Aug 4, 2005 | 07:06 PM
Heatmaker's Avatar
Advanced Member
I see... your talking about the water pump neck... I thought you meant the water pump housing itself was cracked.
Just pull it off the hose, and do as Shoebox reccod cheap part easy fix..
Old Aug 4, 2005 | 10:01 PM
heitz's Avatar
The housing had to be ordered and only cost around twenty bucks but I was just worried about the opti cause I already had it replaced once when my waterpump went out. I was just wondering if there was anything I could do to try to prevent the opti from getting damaged since it already got a little antifreeze on it. Thanks
2QUIK6
Sep 17, 2016 02:31 PM
bunker
Jan 30, 2016 08:09 PM
MikeWhitener
Aug 2, 2015 06:17 PM
LeftoverChinese
Jul 23, 2015 03:57 PM
asilomar244
Jul 12, 2015 05:53 AM
