thermostat ?
Old Jul 22, 2004 | 08:25 PM
SickWS6's Avatar
Question thermostat ?
i just installed my 160 thermostat and after i run it around town or just let it idleit will raise to about 230 to 245 but if i take it on the high way it will stay around 180 also when it gets that hot my low coolent light comes on but i made sure i bled the system so no air was in there. if i just reprogram the computer will this fix it.
Old Jul 22, 2004 | 09:01 PM
CamaroSS30thAnn's Avatar
Re: thermostat ?
230-245 is really high......mine doesnt get that hot after the intall....check ur coolant level again and bleed it again and c what happens.....there is a way to put teh stat in backwards too....did u put it in the right way .....probably not cuz itr seems like it opens up.....also a fan switch or reprogram to get the fans to come on earlier would benefit u alot
Old Jul 23, 2004 | 07:16 PM
SickWS6's Avatar
Re: thermostat ?
anyone else have any ideas
Old Jul 23, 2004 | 07:24 PM
Bow94z's Avatar
Re: thermostat ?
run a fan switch?
Old Jul 23, 2004 | 07:51 PM
jasons93z's Avatar
Re: thermostat ?
mine does the same thing and the fans are fine, and i blead the system
Old Jul 24, 2004 | 12:40 PM
SickWS6's Avatar
Re: thermostat ?
jasons93z have you reprogramed your computer
Old Jul 24, 2004 | 12:50 PM
jdizzell's Avatar
Re: thermostat ?
You have it installed wrong. Yes you have to reprogram your pcm, optimal running temp is 180-220. You do not need a 160.
Old Jul 24, 2004 | 02:17 PM
moparman's Avatar
Re: thermostat ?
You get the right thermostat? The small block Chevy is not correct.
Old Jul 24, 2004 | 02:25 PM
SickWS6's Avatar
Re: thermostat ?
i got the right one
Old Jul 24, 2004 | 02:26 PM
SickWS6's Avatar
Talking Re: thermostat ?
i got the right one
Old Jul 24, 2004 | 03:08 PM
bozobuttz's Avatar
Exclamation Re: thermostat ?
I'm having the same problem. http://web.camaross.com/forums/showthread.php?t=282493
Old Jul 24, 2004 | 10:34 PM
tomatocity's Avatar
Re: thermostat ?
Next week I will be installing a 160* thermostat and hopefully I will not have the same problem(s).
What was your temps before you installed the 160* thermostat? If you did not have these problems before I would start undoing what you did. First of all I would change your programming back to what it was before (stock ?). My understanding is you don't need to reprogram when using a 160* thermostat and that information comes from one of our best resources. Check the coolant level and bleed, bleed, bleed. Check to see if the thermostat is the correct one and that it is installed correctly. All of us make mistakes and I am becoming an expert at them Make sure your fans are connected. Go to Shoebox's page to see how to test them. Test your new thermostat to see if it is opening correctly and at teh correct temperature. If you can get it to work as a stock then start the installation process over again. I am hoping you resolve this problem soon and I want to know what was the problem. It is a lonely world when yuo work on your car alone and things don't work correctly. Thanks the heavens for CamaroZ28.com
Old Jul 24, 2004 | 10:39 PM
Re: thermostat ?
yes reprogramming the computer is nto necessary, but when u want ur car to stay cool and nevr get up to the 210+ mark then reprogramming teh PCM will bring out teh whole benefit of teh 160thermotat
Jeff1904
Jun 5, 2016 05:00 PM
MikeWhitener
Aug 2, 2015 06:17 PM
kylekratzenberg
Jun 29, 2015 05:56 AM
Biggiebound
Apr 23, 2015 08:50 AM
VetteThreat
Jun 18, 2002 01:53 PM
