thermostat
Old Feb 27, 2004 | 04:46 PM
Liquid Teal's Avatar
thermostat
does it take much longer for the 160 to warm up...compared to the stock 180 ? gotta have a good heater you know....
when replacing.....is there a torque ,pattern or anything ?
thanks,
Old Feb 27, 2004 | 04:53 PM
SlickBlack Z's Avatar
Yes, it will take longer for you to get heat...especially in cold climates. There are only 2 bolts on the thermostat housing, just torque them down to spec.
Old Feb 27, 2004 | 05:04 PM
Not sure what the real question is, but the engine will take the same amount of time to reach 160° with either thermostat. It's just that the 160° will then open when the 180° would remain closed until the temp got to 180°.
In cold weather, your running temps will be lower, so your heater will not be as hot, either.
Jeff1904
Jun 5, 2016 05:00 PM
MikeWhitener
Aug 2, 2015 06:17 PM
kylekratzenberg
Jun 29, 2015 05:56 AM
Biggiebound
Apr 23, 2015 08:50 AM
VetteThreat
Jun 18, 2002 01:53 PM
