Thermostat
Old Sep 16, 2003 | 03:29 AM
whitelightening's Avatar
Thermostat
would there be a big difference in a 160 deg. thermo and a 180 deg.? What would be best for my 95? I would also be interested in hearing your opinions on how much of a difference they made on your cars!! any input would be very appriciated!
Thank you,
Justin
Old Sep 16, 2003 | 03:41 AM
InjectedSS's Avatar
Re: Thermostat
Thank you,
Justin
either of them arent going to help at all unless you program your fans to come on sooner!!
Old Sep 16, 2003 | 06:56 AM
sssalah's Avatar
Your temps will reduce by that much if your car is moving at highway speeds, but unless you program the fans or use a cooler fan switch, your temps will be the same is stop and go traffic.
Old Sep 16, 2003 | 07:08 AM
jasons93z's Avatar
Re: Re: Thermostat
you dont NEED to reprogram. Just make a manual fan switch for about $8.
Old Sep 16, 2003 | 11:16 AM
Thanks for the info i will get a fan switch with it then!!
Thank you,
Justin
Old Sep 16, 2003 | 11:25 AM
Dolby109's Avatar
I got a 160 stat, and had my car programmed for the fans to turn on earlier (among several other things) and the car ran a lot better till the opti took a crap.
Jeff1904
Jun 5, 2016 05:00 PM
MikeWhitener
Aug 2, 2015 06:17 PM
kylekratzenberg
Jun 29, 2015 05:56 AM
Biggiebound
Apr 23, 2015 08:50 AM
VetteThreat
Jun 18, 2002 01:53 PM
