AFR 220 heads and valve covers, need help ASAP!
Old Aug 21, 2003 | 07:55 PM
Hoostie's Avatar
Valve Covers for AFR 220's, need help ASAP!
I finally got the moter in and am ready to get her toghter so I can take her down to school. I am building a 396 with afr 220 lt4 heads. The stock valve covers wont fit. Unless I am just stupid, I even hollowed them out, and they still dont fit and there is nothing inside of them. What valve covers can I use? Will lt4 vavle covers work? I need to be able to get a set tommrow to put on the car so hopefully if it runs ok drive it down to school. THanks a lot.
Old Aug 21, 2003 | 08:33 PM
MK 94 1LE's Avatar
I've got 190's on my car and I had to double up the gaskets to make them seal properly. Don't know if that helps any?
Mike
Old Aug 22, 2003 | 01:27 AM
Hoostie's Avatar
I have the heads, I just need the valve covers.
Old Aug 22, 2003 | 01:38 PM
Hoostie's Avatar
anyone?
Old Aug 22, 2003 | 03:06 PM
bkrepindy's Avatar
FWIW, I have the AFR 210 LT4 heads on mine and I am using a set of polished aluminum covers that deminsionally are not much, if any different than the stockers. I used GM gaskets and they work fine. Don't know the brand I picked them up at a swap meet.
Old Aug 22, 2003 | 05:42 PM
TimChiaretto's Avatar
I have AFR 190s. The valve cover are should be the same (?). I put a set of LT4 valve covers on and the only problem was that I to shorten up the threaded area on the valve cover studs because the tapped holes in the AFR heads were not deep enough, ohterwise they fit fine.
Old Sep 16, 2003 | 11:37 AM
brand-x's Avatar
Moroso fabbed (welded) aluminum valve covers...the AFR 220 & 227 heads are based on a different casting (different rail deminsions) than the 210 and smaller heads. Here's a set on my engine:
http://pictureposter.allbrand.nu/pic...e+057.jpg.html
HectorM52
Jul 30, 2017 11:46 AM
Roadie
Feb 16, 2015 10:34 AM
MadMav
Feb 6, 2015 11:02 PM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
