is there a way....
Old Apr 20, 2003 | 07:15 PM
CodysRedZ's Avatar
is there a way....
Is there a way to check for knock on my 94 ob1??? i might be pickin some up! Thanks
Old Apr 20, 2003 | 07:38 PM
Hook up a "scanner".... Auto XRay or ScanMaster for direct readings on hardware scanners.... TTS DataMaster, Diacom or FreeScan for software scans. Both DataMaster and FreeScan can be downloaded free. You just need an interface cable for $50-100 from AKM Electronics.
The scanner will indicate "knock retard" which is the computer's response to a knock signal from the knock sensor. It will not allow you to differentiate between "true" knock... destructive ping or detonation, or "false" knock... mechanical noise from the valve train, for example, but it will tell you if you are losing performance due to timing being pulled.
aaron_depue
Feb 24, 2012 10:42 PM
rangers458
Jan 17, 2011 01:01 AM
1nicelt1
Mar 5, 2010 12:15 PM
NVMYZ28
Jul 13, 2009 11:08 PM
