is there a LT4 Knock sensor?
Old Mar 11, 2006 | 06:40 PM
crAzy95z28's Avatar
cause i have a LT4 knock module that is in the pcm.
What about the block?
also when changing it out will oil or collant fall out of the block>?
Old Mar 11, 2006 | 07:37 PM
Re: is there a LT4 Knock sensor?
No.
There are two different knock sensors for alll LT1 and LT4 engines. OBD-I PCM's need the low impedance one (4,400ohms), OBD-II PCM's need the high impedance (100Kohms). The 96 LT4 engine used the same knock sensor as the 96 LT1.
The knock sensor is threaded into one of the block coolant drain holes.
Old Mar 12, 2006 | 05:08 AM
crAzy95z28's Avatar
ok i just got one for like 30$ from autozone...these any good?
for a 95!
mightymouse383
Jul 20, 2016 07:34 AM
4586
Mar 18, 2015 06:31 PM
IgorT.455/406
Feb 1, 2005 06:18 AM
dreamer1q
Aug 20, 2002 11:19 AM
NJ SPEEDER
Jul 19, 2002 10:22 PM
