Is there a gasket between the Oil Pump and the Block?
Old Nov 25, 2004 | 02:46 PM
BlackLT1_TX's Avatar
I cant find one in my gasket set, and I dont think that there is one, but just want to make sure.
Also, any one know the torque specs on the oil pump, I am running a ARP stud to hold the oil pump, but I just need to know around what to torque it to.
Also, I left a little over a 1/4 inch between the pan bottom and the bottom of the pickup and had it tacked on, that should be fine right. (PS, Im running the M155).
-James
Old Nov 25, 2004 | 03:25 PM
SStrokerAce's Avatar
Re: Is there a gasket between the Oil Pump and the Block?
No gasket there.
You should check the ARP sheet that comes with the stud but It should be 70 ft lbs and make sure you get it there. I like to add some removable locktite to it also to make sure it's on there and not comming off.
Bret
HectorM52
Jul 30, 2017 11:46 AM
DirtyDaveW
Mar 15, 2015 07:01 PM
HectorM52
Parts Wanted
Jan 10, 2015 09:01 PM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
Donwest22
Parts Wanted
Dec 18, 2014 11:10 AM
