Is there a gasket between the Oil Pump and the Block?
I cant find one in my gasket set, and I dont think that there is one, but just want to make sure.
Also, any one know the torque specs on the oil pump, I am running a ARP stud to hold the oil pump, but I just need to know around what to torque it to.
Also, I left a little over a 1/4 inch between the pan bottom and the bottom of the pickup and had it tacked on, that should be fine right. (PS, Im running the M155).
-James
-James
Re: Is there a gasket between the Oil Pump and the Block?
No gasket there.
You should check the ARP sheet that comes with the stud but It should be 70 ft lbs and make sure you get it there. I like to add some removable locktite to it also to make sure it's on there and not comming off.
Bret
Bret
